方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Lipid-conjugated polysaccharide vesicles in nano- and micro-scale were developed from amphiphilic octadecanol-modified dextrans (OMD) prepared by partial esterification of dextran with activated octadecanol-carbamate imidazole in a well-controlled manner. The critical aggregation concentration (CAC) of OMD adducts in aqueous phase varies, depending mainly on their octadecanol contents. Through supramolecular assembly of the OMD adducts comprising either 17 or 28 mol% octadecanol residues with respect to the anhydroglucopyranose units by the partial solvent displacement technique with the initial water content of DMSO/H2O solutions beyond a critical point, stable nano-scaled OMD assemblies were developed and characterized by the vesicle-like morphology. The dimension of polymersomes can be effectively controlled by the OMD composition as well as the initial water content. On the other hand, micro-scaled OMD polymersomes can be achieved by the double emulsion technique in a water/oil/water (w1/o/w2) manner. Both the contents of NaCl in aqueous solution as the w1 phase and of DMSO in DMSO/CHCl3 co-solvents as the organic phase, in which OMD was dissolved, are of great importance in controlling the polymersome morphology and size. These micro-scaled OMD polymersome walls are characterized by size-selective permeability capable of encapsulating large water-soluble cargoes while allowing transport of small polar species across the membrane, thereby rendering these unique colloidal particles of potential applications in biomedical technologies.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
