方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The expansion of various rice starches in solution was studied using dynamic light scattering (DLS) in order to provide information on their microstructure. Hydrodynamic diameters of starch molecules were found to change with solvent conditions. The component starches in the rice varieties studied had similar sizes in pure water (between 125 and 235 nm), but showed different expansion behaviour with changes in salt concentration, with addition of urea (which disrupts hydrogen bonding) and with the addition of 1-butanol (which reduces solvent polarity). Some starches showed a gradually increasing size with increasing [NaCl], while others showed an initial steep increase followed by more gradual behaviour. The size distributions from DLS indicated two (and possibly three) components at about 100 and 1000 nm. The larger component was largely responsible for the expansion with added salt, an effect which is ascribed to the greater ability of larger chains to expand. Chain length distributions (CLD) of debranched starch from the same samples were examined by capillary electrophoresis (CE) for correlation with the expansion behaviour obtained by DLS. The ratio of shorter to longer chains partly correlated with the classes of expansion behaviour. The data suggest that the expansion behaviour is sensitive to the branching structure (connectivity) as well as to the distribution of the lengths of the branches.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
