方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The zeta-potentials of the self-assembled surface ionic surfactants (sodium dodecyl sulfate—SDS and hexadecyltrimethyl ammonium bromide—CTAB) on graphite surfaces were determined both from streaming potential and electrophoretic mobility measurements. The adsorption of the surfactants at graphite–liquid interfaces has been studied using atomic force microscopy (AFM) soft-contact imaging which shows the formation of linear, parallel hemicylinders with headgroups oriented towards the solution. The magnitude of the zeta-potential increased with an increase in surfactant concentration, reaching a constant value at a concentration corresponding to the point of surface micelle formation as confirmed from AFM imaging. The streaming potential and electrophoretic mobility measurements showed that the zeta-potentials of SDS and CTAB surface micelles adsorbed at the graphite surface were about ?75 and +70 mV, respectively, well in agreement with the values reported for bulk phase micelles in the literature.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
