方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Oxygen-transfer enhancement has been observed in the presence of colloidal dispersions of magnetite (Fe3O4) nanoparticles coated with oleic acid and a polymerizable surfactant. These fluids improve gas?liquid oxygen mass transfer up to 6-fold (600%) at nanoparticle volume fractions below 1% in an agitated, sparged reactor and show remarkable stability in high-ionic strength media over a wide pH range. Through a combination of experiments using physical and chemical methods to characterize mass transfer, it is shown that (i) both the mass transfer coefficient (kL) and the gas?liquid interfacial area (a) are enhanced in the presence of nanoparticles, the latter accounting for a large fraction of the total enhancement (80% or more), (ii) the enhancement in kL measured by physical and chemical methods is similar and ranges from 20 to 60% approximately, (iii) the enhancement in kL levels off at a nanoparticle volume fraction of approximately 1% v/v, and (iv) the enhancement in kLa shows a strong temperature dependence. These results are relevant to a wide range of processes limited by the mass transfer of a solute between a gas phase and a liquid phase, such as fermentation, waste treatment, and hydrogenation reactions.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
