方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Sol?gel materials are often reinforced through the addition of particulate fillers to improve their mechanical properties, such as toughness or stiffness. Related studies of filled polymeric materials suggest that the effectiveness of added reinforcements may depend sensitively on the state of particulate aggregation in the composites. In some systems and situations, aggregates are found to enhance properties, while in others they are deleterious. The objective of the present study was to determine the effect of state of aggregation of alumina nanoparticle fillers on the mechanical properties of a GPS sol?gel hybrid composite. Aggregates of different sizes were produced at loadings of 3.6, 7.5, and 16.8 volume percent in the GPS sol?gel monoliths by inducing aggregation through the addition of varying amounts of tetrasodium pyrophospate (TSPP). The small amounts of TSPP required to induce varying states of aggregation did not affect the properties of the gel in the absence of the particles. Unaggregated particles or small aggregates were found to impart significant improvements in the mechanical properties of the gel, but at a particular critical aggregate size and beyond, the cured material cracked and crumbled. The critical size was found to correspond roughly to an effective aggregate volume fraction of 0.64 in the final composite, suggestive of a randomly close-packed aggregate structure.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
