方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In situ near infrared (NIR) spectroscopy is performed simultaneously with automatic continuous online monitoring of polymerization reactions (ACOMP) during methyl methacrylate polymerization. ACOMP is an absolute technique that furnishes weight average molecular mass Mw, intrinsic viscosity, monomer conversion, and other characteristics, whereas NIR furnishes monomer conversion data via an empirical calibration. An advantage of in situ NIR is that it furnishes immediate information on the conversion in the reactor, whereas ACOMP relies on continuous withdrawal and dilution of a small stream of reactor fluid, so that there is a lag time of several minutes between what ACOMP reports and what is occurring in the reactor. Simultaneous monomer conversion data from in situ NIR and ACOMP, the latter derived from both refractive index and UV absorption, are compared and found to be in good agreement. The evolution of conversion kinetics and Mw generally conform to the predictions of the Quasi-Steady State Approximation. Having established the agreement between the methods, the path is now open for combining NIR with ACOMP to characterize increasingly complex systems, such as copolymerization with two or more monomeric species, that are not feasible by either technique separately.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
