方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Using automatic, continuous online monitoring of polymerization reactions (ACOMP) the final, divergent growth phase (FDGP) of the condensation polymerization of dimethylamine, epichlorohydrin, and ethylenediamine was monitored, which produced a highly ramified, polyelectrolytic polyamine. The weight average mass, Mw, increased exponentially during the FDGP, whereas weight averaged intrinsic viscosity [η]w increased slowly, reaching a plateau. Multi-detector gel permeation chromatography (GPC) revealed that polymers of mass 20?000 to 106 are branched and self-similar, but above this mass, [η] increases less strongly with M. This appears to be due to higher order ramification, a precursor to gelation. The ACOMP trends in Mw and [η]w provide direct online evidence of this process. It is shown computationally that a mere increase in polydispersity cannot explain this behavior. GPC showed the mass distribution becomes highly asymmetric as conversion increases. A plausible kinetic model for the distribution asymmetry is introduced, and a complementary model for the effects of higher order ramification on [η]w.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
