方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Magnetic nanoparticles consisting of iron oxide cores modified with covalently linked chitosan oligosaccharide (CSO) that are colloidally stable in water and buffers were obtained. Primary oleic acid coated nanoparticles were synthesized through the thermal decomposition method and the surface ligand exchanged to a carboxylic acid silane. Amide linkage between the chitosan and magnetic nanoparticles was obtained through carbodiimide activation, under conditions which promoted particle stability and chitosan solubility. Magnetic measurements indicate that the particles are superparamagnetic. Measurements of hydrodynamic diameter and zeta potential, coupled with TEM measurements, indicated that CSO coated nanoparticles consist of single primary particles coated with a chitosan corona. These nanoparticles are stable in water for a wide range of pH, and in commonly used biological buffers, such as phosphate buffered saline (PBS), Hank's balanced salt solution (HBSS), and Dulbecco's modified eagle's medium (DMEM) with fetal bovine serum (FBS).
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
