方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Hydrophobic microblock length effect on the interaction strength and binding capacity between a partially hydrolyzed microblock hydrophobically associating polyacrylamide terpolymer and surfactant 作者: Yongjun Guo, Yan Liang, Xueshan Yang, Rusen Feng, Rutong Song, Jingda Zhou and Feilong Gao 摘要:Poly(acrylamide/sodium acrylate/N-dodecyl acrylamide)s [poly(AM/NaAA/C12AM)s] with different hydrophobic microblock lengths (NH's) were prepared by the micellar copolymerization of acrylamide and sodium acrylate with a low amount of N-dodecyl acrylamide (0.2 mol %), and the molecular structure was characterized by Fourier transform infrared spectroscopy, 1H-NMR, and static light scattering. A combination of experiments involving viscosity measurement, fluorescence, and conductometry was applied to investigate the effect of NH on the interaction strength and binding capacity between poly(AM/NaAA/C12AM)s and C12H25SO4Na [sodium dodecyl sulfate (SDS)]. The viscosity, I3/I1 (the intensity ratio of the third vibrational band to the first band of pyrene molecules), and conductivity of the mixed system of copolymers with SDS all had different variation trends with the concentration of SDS. The binding capacity of the copolymers with SDS was calculated according to quantitative differences between the critical micelle concentration of the pure SDS solution and the mixed system. All of the results show that the interaction strength of SDS with the copolymers rose, and the binding capacity decreased with increasing NH. 关键词:copolymers;electrochemistry;spectroscopy;surfactants;viscosity and viscoelasticity
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
