方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Morphological and conformational transitions of lentinan (LT), a ˇ-glucan extracted from Shiitake mush-rooms (Lentinula edodes), were investigated at different concentrations of aqueous NaOH, using SmallAngle X-ray Scattering (SAXS) technique. At low NaOH(aq)concentration LT chains are self-associatedand adopt the triple helix form where as at higher NaOH concentrations the polymer chains undergo atransition to random coil chains. Also, the presence of fractal dimensions was observed through analysisof the exponential decay of the scattering intensity as a function of the scattering angle. In addition, thelateral radius of gyration was determined for LT in different concentrations of NaOH solution, indicating arigid triple helix present as a small rod-like structure. Interactions of LT with two zwitterionic surfactantswere investigated by surface tension, fluorescence, and static light scattering measurements. Experimen-tal data showed that the formation of LT–(surfactant) complexes occurred through a cooperative process.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
