方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Temperature and pH sensitive hydrogels: An approach towards smart semen-triggered vaginal microbicidal vehicles 作者: Kavita M. Gupta, Scott R. Barnes, Rachel A. Tangaro, Meredith C. Roberts, Derek H. Owen, David F. Katz andPatrick F. Kiser 摘要:Microbicides are drug delivery systems (DDSs) for the prevention of sexual transmission of HIV and other STDs. A topically applied vaginal microbicidal gel should provide uniform coating of vaginal tissue, retention of this gel layer prior to intercourse, and controlled release kinetics of antivirals to inactivate the viral load potentially introduced during sexual activity. Here, we describe the microbicide-oriented characterization of a DDS made with a dual pH sensitive and thermosensitive smart polymer gel composed of a random terpolymer of N-isopropyl acrylamide, butyl methacrylate, and acrylic acid. The system was engineered to coat vaginal tissue with a stable gel layer and to release entrapped model agents in a burst release profile in response to the presence of the infecting agent: semen. The gel rheology, layer erosion properties, model drug release kinetics, and cytocompatibility of the terpolymer system were studied. Negligible erosion of the gel in the presence of vaginal fluid simulant suggests prolonged retention. Burst release of molecular and macromolecular model compounds was observed when the system's pH changed from the vaginal pH to the pH of semen, and cytotoxicity studies showed that the terpolymer is equally cytocompatible as a commonly used polymeric vaginal carrier. 关键词:HIV/AIDS;microbicide;formulation vehicle;viscosity;thermal gels;responsive delivery system;semen-triggered drug release;controlled release/delivery;vaginal coating;retention
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
