方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Let’s answer the question first. To do so, we need to know the size of the Au particle and to assume it is monodisperse. In fact, one purpose of this application note is to explore the meaning of monodispersity, despite its literal definition, one size. We chose 5 nm diameter Au nanoparticles. Now the earth has an average circumference of 40,000 km or 4 x 1016 nm. So we need 8 x 1015 particles. That’s a lot of particles. Yet, it corresponds to a total volume of just 5 x 10-4 cm3, approximately. Gold’s density is 19.3 g/cm3. So we need about 10 mg of Au. Not much. Of course, given that high density, it will be hard to keep the particles from sinking into the oceans as we circumscribe the earth, not to mention the tiny tweezers required to manipulate the nanoparticles. But our main goal is to figure out if the size claimed is correct and if the distribution is one size.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
