方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Chemical analysis of cement is an interesting application for ICP spectrometry. The cement industry requires analysis of major elements at % levels to very high accuracy and precision, including Si, Ca, Al, Fe and S and also minor elements such as Na, K, Ti, Mg, P, Mn. The trace elements are also very important for environmental pollution control, this includes species like Cr, Pn, Zn,Ni, As, Cd, V and Cu at ppm levels. All these elements are possible by the ICP technique. The use of a combined ICP-OES, such as the ULTIMA 2C, enables fast analysis of all above mentioned elements. For major elements, the repeatability required is in the range 0.2 to 0.5 %, for this reason the simultaneous component is often used for routine analysis, whereas trace elements are better done on the sequential portion for the superior detection limits.
颗粒分析+混合氧化石墨烯+分散状态的混合比例
颗粒分析+聚苯乙烯乳胶混合样品+粒径分布
颗粒分析+二氧化硅+CMP浆料质量控制
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
