方案下载应用领域 | 地矿 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 0 |
These samples would normally present problems due to the dissolved solids and the presence of HF. The use of the argon humidifier, sheath gas and the large ID injector tube from HORIBA Scientific ensures smooth running of these samples. For HF samples the use of the inert tangential nebulizer and the inert Scott spray chamber is required. The results show excellent detection limits for the original sample. A typical dilution factor would have degraded these figures by a factor of 10 when calculated in the original material.
拉曼+石墨烯+振动探测
拉曼+二维材料+应变工程
拉曼+CO2加氢反应+催化机理
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
