方案下载应用领域 | 环保 |
检测样本 | 废水 |
检测项目 | (类)金属及其化合物>锌(Zn), 锰(Mn), 铅(Pb), 硼(B), 铝(Al), 砷(As), 铬(Cr), 硒(Se), 铁(Fe), 镉(Cd), 镍(Ni), 铜(Cu) |
参考标准 | 0 |
This application illustrates that both quantitative and semi-quantitative methods give good results in a wide range of concentrations (μg/L levels to hundreds of mg/L). The radial viewing allows the user to minimize matrix effects. Note that the fast and precise semiquantitative method can be routinely used. For more applications on semi-quantitative analysis of supply water and sludge from animal food see Application Note 25.
This application illustrates that both quantitative and semi-quantitative methods give good results in a wide range of concentrations (µg/L levels to hundreds of mg/L). The radial viewing allows the user to minimize matrix effects. Note that the fast and precise semiquantitative method can be routinely used. For more applications on semi-quantitative analysis of supply water and sludge from animal food see Application Note 25.
颗粒分析+混合氧化石墨烯+分散状态的混合比例
颗粒分析+聚苯乙烯乳胶混合样品+粒径分布
颗粒分析+二氧化硅+CMP浆料质量控制
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
