椭圆偏振光谱仪测量化合物半导体:AlxGa1-xNGaN异质结构
2016/09/22   下载量: 4
方案下载
应用领域 电子/电气
检测样本 其他
检测项目
参考标准 0
Liquid Crystal Modulation Spectroscopic Ellipsometry is an excellent technique for the highly accurate characterization of the compound semiconductor heterostructure AlGaN / GaN. Using the MM-16 spectroscopic ellipsometer it is a straightforward procedure to determine the film thickness and optical dispersions of the complete structure even where the film is several microns thick. The detailed knowledge of the optical parameters of AlGaN alloys is crucial for example for the design of opto-electronic devices. Furthermore, from the optical parameters a calibration curve could be constructed to provide a rapid and efficient determination of the Al content in the AlGaN layers. Thus Spectroscopic Ellipsometry also proves a non-destructive technique for AlGaN alloy composition determination. This method can be equally applied to other compound semiconductors such as SiGe, II-VI semiconductors or classical III-V semiconductors.
方案下载
配置单
方案详情
上一篇 荧光光谱+蛋白质检测+荧光特性
下一篇 使用MM-16椭圆偏振光谱仪表征并五苯有机薄膜晶体管
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 椭圆偏振光谱仪测量化合物半导体:AlxGa1-xNGaN异质结构
