方案下载应用领域 | 环保 |
检测样本 | 环境水(除海水) |
检测项目 | 无机阴离子>氯离子 |
参考标准 | 无 |
ICP-OES is a multi-element technique that allows the determination of 75 elements in the periodic table. One element that is desirable to analyze at the same time as other elements is chlorine. However, until recently, the analysis of halogens,especially chlorine, was usually not undertaken by ICP. This was because the halogens are not easy to excite in a plasma source and their emission wavelengths are challenging for conventional optics. Chlorine wavelengths, which yield good sensitivity, are low (133 nm and 134 nm) and are not possible to measure with conventional solidstate detectors or photomultiplier tubes. This Application Note describes recent hardware improvements that allow the determination of Cl,Br and I by ICP-OES.
颗粒分析+混合氧化石墨烯+分散状态的混合比例
颗粒分析+聚苯乙烯乳胶混合样品+粒径分布
颗粒分析+二氧化硅+CMP浆料质量控制
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
