方案下载应用领域 | 建材/家具 |
检测样本 | 建筑玻璃 |
检测项目 | |
参考标准 | 0 |
The relatively clean spectrum of glass constituents enables the use of the JY 2000-2 without the need of the high resolution of the ULTIMA 2. The results show excellent agreement with expected results for all element, both major constituents and traces. The use of sequential internal standard has been shown to compensate for any viscosity differences between the samples and standards. The speed of analysis of less than 2 minutes for the 10 elements determined, and the detection limits achieved, are more than adequate for laboratories doing ordinary glass analysis. Although both acid and fusion methods were tried, afusion would appear to fulfil the requirements of full analysis in one sample preparation. If lower detection limits are required for some of the trace elements, then an HF acid digestion will be required as well.
颗粒分析+混合氧化石墨烯+分散状态的混合比例
颗粒分析+聚苯乙烯乳胶混合样品+粒径分布
颗粒分析+二氧化硅+CMP浆料质量控制
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
