采用ICP-AES测定水中氯离子
2017/12/25   下载量: 17
方案下载
应用领域 环保
检测样本 环境水(除海水)
检测项目
参考标准
ICP-OES is a multi-element technique that allows the determination of 75 elements in the periodic table. One element that is desirable to analyze at the same time as other elements is chlorine. However, until recently, the analysis of halogens,especially chlorine, was usually not undertaken by ICP. This was because the halogens are not easy to excite in a plasma source and their emission wavelengths are challenging for conventional optics. Chlorine wavelengths, which yield good sensitivity, are low (133 nm and 134 nm) and are not possible to measure with conventional solidstate detectors or photomultiplier tubes. This Application Note describes recent hardware improvements that allow the determination of Cl,Br and I by ICP-OES.
方案下载
配置单
上一篇 荧光光谱+有机掺杂材料+构建
下一篇 采用发射光谱法测定铋中钒含量
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 采用ICP-AES测定水中氯离子
