方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Fluorescence microscopy has become an indispensable tool in cell biology because it allows specifi c proteins to be visualized. Atomic force microscopy (AFM) is also becoming extensively used in the life sciences, but its development has largely followed an independent path and is used for somewhat different, but often complementary, purposes. Both methods can be applied to hydrated biological samples. Fluorescence microscopy is routinely used to image and track specifi cally labeled biological molecules in situ, illuminating a wide variety of cellular processes. In contrast, AFM is used for high spatial resolution imaging but also introduces the possibility of mechanically probing and manipulating samples without the need of complicated sample preparation. In this note, we briefl y describe the application of an AFM mounted on an inverted optical microscope to the characterization of the morphology of axons from cultured chick neurons using specifi c fl uorescent immunostaining and topographic imaging with AFM.
台阶仪在三维形貌表征领域的应用
3D surface Profi ling applications
双焦面实时超高分辨系统Bruker3DVutura
多功能双光子成像平台Bruker2pplus
高品质双光子成像系统BrukerInvestigator
场扫描共聚焦成像系统BrukerOpterra II
布鲁克透射电镜专用原位纳米力学系统PI 95
布鲁克电镜专用原位纳米力学测试系统PI 88
布鲁克电镜专用原位纳米力学系统 PI 85L
布鲁克高精度纳米力学测试系统TI Premier
布鲁克高精度纳米力学测试系统TI 980
布鲁克三维光学显微镜Contour Elite
摩擦磨损试验机UMT-TriboLab
布鲁克原子力显微镜Dimension FastScan
探针式表面轮廓仪DektakXT
光学轮廓仪NPFLEX 3D
扫描探针显微镜系统Dimension Edge
