方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The atomic force microscope (AFM) is a sensitive force measurement instrument. But sensitivity and measurement accuracy are two different issues. This application note describes a solution for improving the accuracy of AFM force measurements through more precise calibration of the AFM cantilever spring constant. There are several well-documented methods for calibrating the spring constant, but the one described here offers not only improved precision, but also ease of use and speed, because the procedure is straightforward, and relies only on the AFM’s own hardware and software.
台阶仪在三维形貌表征领域的应用
3D surface Profi ling applications
双焦面实时超高分辨系统Bruker3DVutura
多功能双光子成像平台Bruker2pplus
高品质双光子成像系统BrukerInvestigator
场扫描共聚焦成像系统BrukerOpterra II
布鲁克透射电镜专用原位纳米力学系统PI 95
布鲁克电镜专用原位纳米力学测试系统PI 88
布鲁克电镜专用原位纳米力学系统 PI 85L
布鲁克高精度纳米力学测试系统TI Premier
布鲁克高精度纳米力学测试系统TI 980
布鲁克三维光学显微镜Contour Elite
摩擦磨损试验机UMT-TriboLab
布鲁克原子力显微镜Dimension FastScan
探针式表面轮廓仪DektakXT
光学轮廓仪NPFLEX 3D
扫描探针显微镜系统Dimension Edge
