方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
An ongoing research ramjet program initiated at ONERA under support of DGA (French ministry of Defence) aims to improve methodology for ramjet combustion chamber design and tuning by using validated CFD codes. A transparent model rig was used for aerodynamic tests with air flows at atmospheric pressure and room temperature. In the case of the simulation of a Solid Ducted Rocket (SDR) combustor, two fuel holes were located at the head end of the combustor in order to simulate the fuel supply from the auxiliary gas generator in the case of a real combustor. Among the various mechanisms that are controlling the development of the combustion processes inside the combustor, the mixing is certainly one of the most crucial as far as stability or efficiency are concerned. The work presented in this paper is addressing the characterization, in absence of combustion, of the turbulent flow velocity and scalar fields associated to the mixing between fuel (simulated by CO2) and air. Particle image velocimetry (PIV) and gas sampling analysis are the two techniques that were used to serve that purpose. Results presented in this paper are very useful to assess the ability of numerical computations, based either on Reynolds-Averaged Navier-Stokes (RANS) or Large-Eddy Simulations (LES) approaches, to reliably predict velocity and fuel concentration fields inside this research combustor.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
