方案下载应用领域 | 其他 |
检测样本 | 润滑油 |
检测项目 | |
参考标准 | 暂无 |
Grease is commonly used to lubricate various machine components such as rolling element bearings, open gears etc. Better understanding of the flow properties of grease will contribute to understanding the lubrication mechanism in bearings and flow in lubrication systems. In an earlier paper Micro Particle Image Velocimetry (μPIV) techniques were used to study the flow in a rectangular channel. The present paper is an extension of this work where restrictions were applied in such a channel, which creates a much more complex velocity field. The grease is seeded with fluorescent particles, which are illuminated by a double-pulsed laser. The test geometries that are used in this study are a channel with one flat restriction and one with two flow restrictions in a similar channel. The stationary grease mass-flow and the two dimensional velocity fields have been monitored for different pressure drops. For the channel with one flat restriction, the flow was measured to be symmetric at the inlet and outlet, and the distance for the flow to fully develop is comparable with the height of the channel; Slow motion was followed near the step corner at the inlet. For the channel with two flow restrictions, the vector profiles show that the maximum velocity appears at the restrictions; In-between the two restrictions, a part of the grease is not moving. This particularly applies to cases with low-pressure drop and where high consistency grease was used.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
