方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In this paper we experimentally study the effect of collision properties of different particle systems on the bed dynamics of a spout fluidized bed. This is done for different flow regimes: the spout-fluidization regime (case A), the jet-in-fluidized-bed regime (case B) and the spouting-with-aeration regime (case C). The considered particle systems comprise glass beads, -alumina oxide and zeolite 4A particles, which are all classified as Geldart D. A nonintrusive measurement technique is used, viz. particle image velocimetry (PIV) to measure the particle flow field in a pseudo two-dimensional (2D) spout fluidized bed. Additionally, digital images are analyzed using a newly developed digital image analysis (DIA) algorithm to evaluate the particle volume fraction. It is demonstrated that the new proposed DIA algorithm provides reliable information on the particle volume fraction distribution, showing that it is a powerful tool when combined with PIV. The added value of DIA is confirmed by comparing the particle velocity fields and volumetric particle fluxes. The effect of the collision properties for glass beads, - alumina oxide and zeolite 4A particles has been studied in three flow regimes, i.e. the intermediate/spout-fluidization regime (case A), the jet-in-fluidizedbed regime (case B) and the spouting-with-aeration regime (case C). For each flow regime, the particle volume fraction shows small differences between the different particle systems. For the -alumina oxide and zeolite 4A particles, the spout channel is less stable for the cases A and C. The particle fluxes display also small differences between the particle systems for each flow regime.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
