方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
We investigated the detailed kinematics and wake structure of lesser dog-faced fruit bats (Cynopterus brachyotis) flying in a wind tunnel. High speed recordings of the kinematics were conducted to obtain three-dimensional reconstructions of wing movements. Simultaneously, the flow structure in the spanwise plane perpendicular to the flow stream was visualized using time-resolved particle image velocimetry. The flight of four individuals was investigated to reveal patterns in kinematics and wake structure typical for lower and higher speeds. The wake structure identified as typical for both speed categories was a closed-loop ring vortex consisting of the tip vortex and the limited appearance of a counter-rotating vortex near the body, as well as a small distally located vortex system at the end of the upstroke that generated negative lift. We also investigated the degree of consistency within trials and looked at individual variation in flight parameters, and found distinct differences between individuals as well as within individuals. Supplementary material available online at http://jeb.biologists.org/cgi/content/full/213/20/3427/DC1 Key words: bat flight, kinematics, wake structure.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
