方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Vertical slot fish passes have been applied as a solution to mitigate fish migration problems in running waters, for over two decades. They are commonly used to enable target fish to ascend through obstacles in rivers. However, small species are rarely considered in such fishways, of which the performance for small fish still remains unknown. This experiment was to study the turbulence structure in a vertical slot fish pass concerning two different pool length/width ratios of 9 and 6.67 as well as the effect of installing a cylinder behind the slot in affecting the characteristics of instationary flow. Cylinders are considered an effective solution to modify the flow structure and to reduce velocity and turbulent energy in order to adapt the flow for the passage of small fish species. Flow visualization and particle image velocimetry were used to study the characteristics of mean flow and turbulence and particular emphasis on the unsteady flow. The results show that flow patterns consist of a water jet and one or two recirculation zones depending on the length/width ratio of the pool. The direction of the jet was strongly affected by the vertical cylinders. The frequencies and spatio-temporal evolutions of the main jet beats were analyzed. Combining with the previous studies of fish migration experiments, the results provide hydraulic evidence on the biological performance.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
