方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Recent years have seen an increasing interest in micro aerial vehicles (MAVs) and flapping flight in connection to that. The Delft University of Technology has developed a flapping wing MAV, “DelFly II”, which relies on a flapping bi-plane wing configuration for thrust and lift. The ultimate aim of the present research is to improve the flight performance of the DelFly II from both an aerodynamic and constructional perspective. This is pursued by a parametric wing geometry study in combination with a detailed aerodynamic and aeroelastic investigation. In the geometry study an improved wing geometry was found, where stiffeners are placed more outboard for a more rigid in-flight wing shape. The improved wing shows a 10% increase in the thrust-to-power ratio. Investigations into the swirling strength around the DelFly wing in hovering flight show a leading edge vortex (LEV) during the in- and out-stroke. The LEV appears to be less stable than in insect flight, since some shedding of LEV is present.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
