方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The draft tube of a hydraulic turbine is the component where the flow exiting the runner is decelerated, thereby converting the excess of kinetic energy into static pressure. However, in some refurbishment cases, the installation of an upgraded runner with an old drafttube leads to an undesirable efficiency drop as the discharge is increased above the best efficiency point value. It is found to be related to a corresponding sudden variation in the draft tube pressure recovery coefficient at the same discharge. The model of a recent refurbishment which presents this instability is installed in the CREMHyG test rig. Steady and unsteady measurements of velocity and pressure fields of the complex and highly turbulent swirling flow exiting the runner have been carried out at CREMHyG (Grenoble). They included the three components of the velocity. The flow in the draft tube is rich in secondary flows and possible flow separation due to the elbow as well as to the divergent shape of this geometry. Pressure and velocity field measurements in the draft-tube have been performed. They let us identify some phenomena that may explain the origin of the unusual behavior of the draft tube. Finally, the same model, with a modified draft tube geometry that was designed to reduce the efficiency drop phenomenon has been installed. Velocity measurements were made to validate the benefit of such geometry modification.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
