方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Various types of capacitively coupled radio frequency (CCRF) discharges are frequently used for different applications ranging from chip and solar cell manufacturing to the creation of biocompatible surfaces. In many of these discharges electron heating and electron dynamics are not fully understood. A powerful diagnostic to study electron dynamics in CCRF discharges is phase resolved optical emission spectroscopy (PROES). It is non-intrusive and provides access to the dynamics of highly energetic electrons, which sustain the discharge via ionization, with high spatial and temporal resolution within the RF period. Based on a time dependent model of the excitation dynamics of specifically chosen rare gas levels PROES provides access to plasma parameters such as the electron temperature, electron density and electron energy distribution function (EEDF). In this work the method of PROES is reviewed and some examples of its application are discussed. First, the generation of highly energetic electron beams by the expanding sheath in geometrically symmetric as well as asymmetric discharges and their effect on the EEDF are investigated. Second, the physical nature of the frequency coupling in dual frequency discharges operated at substantially different frequencies is discussed. Third, the generation of electric field reversals during sheath collapse in single and dual frequency discharges is analysed. Then excitation dynamics in an electrically asymmetric novel type of dual frequency discharge is studied. Finally, limitations of PROES are discussed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
