方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Electric field reversals in single and dual-frequency capacitively coupled radio frequency discharges are investigated in the collisionless (1 Pa) and the collisonal (65 Pa) regimes. Phase resolved optical emission spectroscopy is used to measure the excitation of the neutral background gas caused by the field reversal during sheath collapse. The collisionless regime is investigated experimentally in asymmetric neon and hydrogen single frequency discharges operated at 13.56MHz in a GEC reference cell. The collisional regime is investigated experimentally in a symmetric industrial dual-frequency discharge operated at 1.937 and 27.118 MHz. The resulting spatio-temporal excitation profiles are compared with the results of a fluid sheath model in the single frequency case and a particle-in-cell/Monte Carlo simulation in the dual-frequency case. The results show that field reversals occur in both regimes. An analytical model gives an insight into the mechanisms causing the reversal of the electric field. In the dual-frequency case a qualitative comparison between the electric fields resulting from the PIC simulation and from the analytical model is performed. The field reversal seems to be caused by different mechanisms in the respective regimes. In the collisionless case it is caused by electron inertia, whereas in the collisional regime it is caused by a combination of the low mobility of electrons due to collisions and electron inertia. Finally, the field reversal during the sheath collapse seems to be a general source for energy gain of electrons in both single and dual-frequency discharges.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
