方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Angular Domain Imaging (ADI) employs an angular filter array to accept photons within a small acceptance angle along the axis of an aligned laser light source and preferentially reject scattered light. Simulations show that the accepted photons travel the shortest paths between source and detector and are therefore the earliest to arrive. We fabricated angular filter arrays using silicon bulk micromachining and found that an array of 60 μm square shape microtunnels 1 cm in length accepted photons within 0.48 degree of axis of the micro-tunnels. This small acceptance angle rejected most of the scattered light and sub-millimeter resolution targets could be resolved in a few centimeters of turbid medium with at least six times reduced mean free path. ADI through media with higher scattering coefficients was not achievable due to unwanted acceptance of late arriving scattered photons. To reject the late arriving photons, we added time-domain filtration and linear polarization to ADI. The implementation of a time-gated camera, a 780 nm femtosecond pulsed laser, and linear polarization to our ADI system resulted in improved image contrast. The use of ADI with time-gating (gate width 250 ps) and linear polarization enabled visualization of sub-millimeter absorbing objects with approximately eight times higher image contrast compared to ADI in a scattering medium equivalent to six times reduced mean free path.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
