方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Detailed atomization measurements in actual sprinklers are needed for proper spray specification in suppression modeling and analysis. In basic pendant sprinkler configurations, the spray originates from two streams corresponding to flow deflected along the tines of the pendant and flow passing through the void spaces between the tines. In this study, measurements of flow splits (between space and tine streams), sheet breakup distances, drop size, and drop velocity measurements were performed over a range of sprinkler geometries and injection pressures to characterize the near-field sprinkler spray. These detailed measurements were used to support the development of scaling laws describing the effects of injector geometry and injection conditions on sprinkler discharge characteristics.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
