方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Corning® Advanced-Flow™ glass reactors are continuous flow reactors with hydraulic diameter in the range of millimetres. These devices make possible the switch of chemical reactions from batch mode to continuous processing through more efficient, more economical and safer processes. In addition, these reactors provide a platform for developing innovative chemistries that have never been considered industrially practical, either for hazard or yield reasons. Corning proprietary apparatuses are compact, adaptable and scalable, optimizing overall production cost and quality of high-value specialty, fine, and pharmaceutical chemicals. Corning Advanced-Flow™ glass reactors are composed of multiple inter-connected glass devices having different designs, offering the advantages of process intensification and glass-specific qualities like transparency and very good chemical resistance. This paper presents the comparison between experimental and CFD modelling results of a family of Corning glass devices aiming at achieving and maintaining very efficient mixing along the dwell time path. Numerical results are compared to experimental data: velocity profiles measured by micro-PIV means, pressure drop and heat transfer coefficient. The satisfactory agreement between experimental results and CFD modelling proved the utility of numerical simulations in the development of new designs. Therefore, CFD tools help on one hand to predict the performance of new devices and on the other hand to optimize their design in order to improve their behaviour. Thus, CFD simulation facilitates the design and reduces time and cost for the investigation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
