采用基于NADPH的荧光寿命成像法选择性探测多核形细胞中NADPH氧化酶
2011/03/27   下载量: 4
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
NADPH oxidase (NOX2) is a multisubunit membrane-bound enzyme complex that, upon assembly in activated cells, catalyses the reduction of free oxygen to its superoxide anion, which further leads to reactive oxygen species (ROS) that are toxic to invading pathogens, for example, the fungus Aspergillus fumigatus. Polymorphonuclear cells (PMNs) employ both nonoxidative and oxidative mechanisms to clear this fungus from the lung. The oxidative mechanisms mainly depend on the proper assembly and function of NOX2. We identified for the first time the NAD(P)H-dependent enzymes involved in such oxidative mechanisms by means of biexponentialNAD(P)H-fluorescence lifetime imaging (FLIM). A specific fluorescence lifetime of 3670±140 picoseconds as compared to 1870 picoseconds for NAD(P)H bound to mitochondrial enzymes could be associated with NADPH bound to oxidative enzymes in activated PMNs. Due to its predominance in PMNs and due to the use of selective activators and inhibitors, we strongly believe that this specific lifetime mainly originates from NOX2. Our experiments also revealed the high site specificity of the NOX2 assembly and, thus, of the ROS production as well as the dynamic nature of these phenomena. On the example of NADPH oxidase, we demonstrate the potential of NAD(P)H-based FLIM in selectively investigating enzymes during their cellular function.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 缝槽气膜冷却流动特性的最小介入扰动诊断的实验研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 采用基于NADPH的荧光寿命成像法选择性探测多核形细胞中NADPH氧化酶
