方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 其他>其他 |
参考标准 | 暂无 |
In-cylinder PIV measurements have been made during the latter half of the intake stroke on a plane between the inlet valves for a single cylinder optical engine operating at engine speeds of 750, 2000 and 3500 rpm. Mean vector fields for an area of 42 mm by 34 mm have been produced with vectors at approximately 1 mm resolution. The vector fields show the development of the flow field in 1.6°, 2.4° and 3.2° steps for the three respective engine speeds. Tumble ratios have been calculated from these vector fields which show that a change in the flow regime occurs between 2000 and 3500 rpm. This is caused by one of rotating vortices becoming detached from the descending piston at the highest engine speed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
