方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A new experimental procedure for performing simultaneous, phase-separated velocity measurements in two-phase flows is introduced. Basically this Particle Image Velocimetry (PIV) technique is a combination of the three most often used PIV techniques in multiphase flows: PIV with fluorescent tracer particles, shadowgraphy and the digital phase separation with a masking technique. In order to combine the advantages of these multiphase-PIV methods a new PIV setup was developed. With this setup the velocity distributions of the two phases are measured simultaneously with only one b/w camera. This experimental set-up is aimed at providing a means for characterizing the modification of turbulence in the liquid phase by bubbles, this phenomenon is often called “pseudo-turbulence” (van Wijngaarden, 1998).
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
