方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Auto-ignition phenomena with relevance to lean premixed prevaporised (LPP) combustion have been investigated with laser-optical methods. A generic mixing reactor with optical access was set up, offering the possibility to observe the reaction within a droplet laden hot air flow (up to 1100 K) at elevated pressure levels (0.8 MPa). The measurements aim at a detailed understanding of the local conditions under which auto-ignition and combustion occur in the mixing duct. The onset of chemical reactions in the fuel-air mixture was imaged by planar laser-induced fluorescence (LIF) of formaldehyde (CH2O). Formaldehyde is formed during reaction progress leading to auto-ignition and consecutively consumed during combustion. Simultaneous imaging of droplet Mie scattering was applied to study the correlation of their location with the ignition. Furthermore, the chemiluminescence signal of the flame was analysed, using a high-speed ICCD camera system, in order to track the propagation of the individual ignition spots.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
