方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Electrostatic, rotating bell (ESRB) application is one of the most important coating application techniques for industries with demanding specifications for optical attractiveness of coatings, such as automotive. The ESRB process involves production of droplets using a high-speed rotating bell, which are subsequently transported to the substrate being coated via shaping air [1-3]. An electrical potential is applied between the bell and the substrate which further helps droplet atomization and transport. This research investigates the effects of inertia, centrifugal force, drag force, and electrostatic force on the atomization mechanism and particle size distribution using an automotive OEM base coat formulation. Coating flow rate (CFR), shaping air flow rate (SAFR), bell speed (BS), and electrostatic potential (EP) were used as primary parameters to create various atomization conditions and particle size distributions. The atomization mechanism, ligament formation, and particle size distribution were measured using high-speed laser shadowography and image processing. The effects of governing forces and particle size generated on efficiency of droplet transfer to the substrate and optical appearance of the coatings were studied to generate operating windows for optimum process efficiency and appearance.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
