方案下载应用领域 | 交通 |
检测样本 | 汽车电子电器 |
检测项目 | |
参考标准 | 暂无 |
For dense sprays such as those encountered in diesel or gasoline direct injection, the interpretation of spray images is complicated by the fact that most of the light reaches the detectors after multiple scattering events within the spray. This may introduce severe errors when extracting quantitative or even qualitative information from these images as many diagnostics rely on the assumption of single photon scattering. It has recently been shown that the multiple scattering component of spray images can be effectively suppressed if sets of structured light sheets are used to illuminate the spray. The aim of this report is to illustrate the potential and the limitations of this technique for the visualization of sprays from modern diesel and gasoline injectors at elevated atmospheric pressures. The results clearly show that conventionally recorded images are dominated by multiple scattering, causing the light sheet to widen substantially and obscuring details within the light sheet plane. In contrast, multiple scattering and indirect reflections can be suppressed using structured light sheets and proper image processing. Careful interpretation of the corresponding images reveals details of the inner spray structure and thus contributes to the understanding of the complicated spray break-up and atomization processes.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
