方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
To quench a thermal runaway reaction in a chemical rector, an efficient approach is the introduction of a small quantity of a liquid inhibiting agent, named a “killer”, into the mixing vessel. In this thesis, an experimental approach has been coupled tightly with numerical modelling using Computational Fluid Dynamics (CFD). The first part of this thesis is devoted to a study of the hydrodynamics of partially-baffled mixing vessels, including the free-surface deformation caused by the central vortex. The use of an inhomogeneous, multiphase approach allowed simulation of the free-surface deformation. The capability of this novel method was demonstrated by very good agreement between the numerical predictions and experimental data. In the second part, liquid jet injection at the free-surface was coupled with the vessel hydrodynamics. Numerical results, obtained using an Eulerian-Lagrangian approach, have again shown good agreement with experimental data. These results allowed the jet trajectory to be modelled and its penetration into the agitated vessel was quantified. New mixing criteria were introduced that are specific to this application. Finally, the numerical methods validated at the pilot scale were applied at the industrial scale and allowed the proposal of practical improvements to the safety of the synthesis reactors studied.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
