方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The aim of this study is to improve our knowledge of the processes that lead to clay smear during faulting of a layered sand-clay sequence in an analogue sandbox model. We carefully characterized mechanical properties of the materials used by a series of geotechnical tests. Displacement field was quantified using PIV (Particle Image Velocimetry). The model is water-saturated to allow the deformation of wet clay and sand in one experiment comprising a sand package with a horizontal layer of clay above a predefined rigid basement fault. The thickness and rigidity of the clay layer are the parameters varied in this study. The model shows a range of structures that are related to competence contrast between sand and different clay types. Results show ductile shearing of soft clay with a transition to brittle fracturing of stiff clay accompanied by the formation of rotating clay blocks in the fault zone. Localized deformation is observed through time showing (i) the propagation of one active fault migrating laterally through the sediment package, and (ii) the formation of a stable prism between two or more active faults that gets progressively smaller with minor rotation of the hanging wall fault. Continuous clay smear is observed resulting from the lateral injection of clay as well as from a reworked mixture of sand and clay.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
