方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
This research investigated multiple detonation diffraction events in order to better understand the limits and benefits of diffraction strategies with respect to pulse detonation engine design. Hydrogen/air detonations were generated using swept ramp obstacles in a 1.27 m long channel with a cross section of 25.4 mm by 88.9 mm and were diffracted into various multiple-stepped openings. This allowed the detonation wave diffraction transmission limits to be determined for hydrogen/air mixtures and to better understand reinitiating mechanisms throughout the diffraction process. Tests were conducted for area ratios ranging from 2.00–2.60 with varying equivalence ratios from 0.5–1.5. Computational methods were used to better understand the diffraction phenomenon using a series of sensitivity studies for different chemistry sets, computational cell size and equivalence ratio. Experimental tests used combined optical shadowgraph and particle image velocimetry imaging systems to provide shock wave detail and velocity information. The images were observed through a newly designed explosive proof optical section and split flow detonation channel. It was found that area ratios of 2.0 could survive single and double diffraction events over a range an equivalence ratio range of 0.8 to 1.14 Area ratios of 2.3 survived the primary diffraction event for equivalence ratios near stoichiometric for the given step length. Detonation diffraction for area ratios of 2.6 did not survive the primary diffraction event for any equivalence ratio and were unable to transmit to a larger combustor.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
