方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A complementary experimental and computational study of plunging breaking waves is presented that are generated in a two dimensional open channel flume using a bottom bump and impulsive accelerated flow. The time evolution of the transient wave and its flow properties are measured using experimental fluid dynamics (EFD): upstream and downstream velocity and flow rates using pitot probes; air-water interface elevation measurements and two dimensional particle image velocimetry in the wave breaking region. The computational fluid dynamics (CFD) methods are: Cartesian grid; embedded- boundary; hybrid HSM/GF/particle level set and VOF methods, and LES. CFD wave profiles at various time steps identifies the overall wave breaking process and major events: max wave height, first plunge, oblique splash-up, vertical jet, air entrainment, two repeats of these processes, dissipation and wave swept downstream which is qualitatively validated by EFD results. Both EFD and CFD results showed two subsequent plunging and splash-up events after the first plunge. After the wave breaks, the flow trends in mean velocity and vorticity observed in EFD are very similar to CFD which has more detailed resolutions of plunging, splashing, vertical jet and bubble entrainment. Current studies also revealed the occurrence of chaotic multiple splash-up events after the third plunging that produce span-wise vorticity and turbulence. Generation of a clockwise rotating bump vortex and an anticlockwise rotating span-wise wave breaking vortex that is created from the entrapped air after the breaking which transports turbulence from the trough towards the bulk fluid, were identified as the two important events. Mean values of turbulent kinetic energy (TKE) below the broken wave showed that the TKE levels increase by almost 90% after the first plunge and another 40% after the second plunge, after which as the wave is swept downstream by the accelerating mean flow the TKE dissipates.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
