方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Abstract We have experimentally detected a new effect, turbulent thermal diffusion, as predicted theoretically by Elperin et al. (Phys Rev Lett (1996) 76:224–228) and associated with the turbulent transport of inertial particles. The essence of this effect is an appearance of a non-diffusive mean flux of particles in the direction of the mean heat flux. This results in formation of large-scale inhomogeneities in the spatial distribution of inertial particles that are accumulated in regions of minimum mean temperature in the surrounding fluid. The experiments were performed in oscillating grids turbulence with an imposed mean temperature gradient. We used Particle Image Velocimetry to determine the turbulent velocity field, and an Image Processing Technique based on the analysis of the intensity of the Mie scattering to determine the spatial distribution of tracer particles. Analysis of the intensity of laser light Mie scattering by tracer particles showed that the tracer particles accumulate in the vicinity of the minimum of the mean temperature. The latter finding confirms the existence of the effect of turbulent thermal diffusion.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
