方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In this paper, we examine the occurrence of cavitation in the tip region of a waterjet pump, and use the observations to identify key features of the flow structure. The rotor, stator and pump casing in our recently upgraded facility are made of acrylic, whose refractive index matches that of the working fluid, a concentrated aqueous solution of sodium iodide. Such matching makes the blades invisible, enabling flow structure visualization and optical measurements without any obstructions. Our initial tests with fresh water focus on cavitation in the vicinity of the tip region close to design conditions. Near the leading edge, cavitation inception near the tip corner of the pressure side causes accumulation of bubbles along the pressure side of the corner until mid blade. As roll-up of the tip leakage vortex (TLV) starts in the mid blade region, these bubbles travel across the tip-clearance to the suction side, and become nuclei for cavitation inception in the TLV. As the TLV migrates to the vicinity of the pressure side of the neighboring blade it bursts, generating a cloud of bubbles that spreads over most of the aft section of the passage. The leakage flow in the tip gap along the aft side of the blade is strong enough to cause sheet cavitation within the gap, starting from the pressure side corner. The paper also presents preliminary Particle Image Velocimetry (PIV) data concentrating on the roll-up of TLV. Results are consistent with observed cavitation phenomena.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
