方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Tomographic particle image velocimetry is a 3D PIV technique based on the illumination, recording, reconstruction and analysis of tracer-particle motion within a three-dimensional measurement volume. The recently developed technique makes use of several simultaneous views of the illuminated particles, typically 4, and their three-dimensional reconstruction as a light-intensity distribution by means of optical tomography. The reconstruction is performed with the MART algorithm (multiplicative algebraic reconstruction technique), yielding a 3D distribution of light intensity discretized over an array of voxels. The reconstructed tomogram pair is then analyzed by means of 3D crosscorrelation with an iterative multigrid volume-deformation technique, returning the three-component velocity vector distribution over the measurement volume. The implementation of the tomographic technique in time-resolved mode by means of high repetition rate PIV hardware has the capability to yield 4D velocity information. The first part of the chapter describes the operation principles and gives a detailed assessment of the tomographic reconstruction algorithm performance based upon a computer-simulated experiment. The second part of the chapter proposes four applications on two flow cases: 1. the transitional wake behind a circular cylinder; 2. the turbulent boundary layer developing over a flat plate. For the first case, experiments in air at ReD = 2700 are described together with the experimental assessment of the tomographic reconstruction accuracy.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
