方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Introduction Particle image velocimetry (PIV) has proven its strength as a flow diagnostic tool to characterise instantaneous velocity fields and derived quantities such as vorticity. Recent efforts apply momentum conservation principles on planar velocity data in order to extract more quantities, such as pressure fields and integral aerodynamic forces. The theoretical concepts for this 憄lanar pressure imaging? (PPI) have been established and its practical implementation for steady (or time-averaged) flows under approximately 2D flow conditions has been demonstrated (e.g. Baur and K鰊geter 1999, Gurka et al. 1999, Oudheusden et al. 2007). The next challenge is to extend PPI to unsteady flows. This extension can be done on basis of time-resolved flow diagnostics such as time-resolved PIV (TR-PIV), cf. Kurtulus et al. 2007. Instantaneous pressure fields are particularly interesting in bluff-body flows and in fluid-structure interactions, both are important in e.g. wind-engineering applications. A serious complication in extending the planar approach is that flows tend to develop 3D instantaneous structures even for nominally 2D configurations, especially at larger Reynolds numbers.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
