方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Stereoscopic Planar Image Velocimetry (SPIV) has been applied to obtain the three components of the instantaneous velocity vectors on a vertical plane above the burner outlet where the flames propagate. The instantaneous temperature fields have been determined through Laser Induced Rayleigh (LIRay) scattering. Planar Laser Induced Fluorescence (PLIF) on acetone has been used to calculate the average equivalence ratio distributions. Instantaneous turbulent burning velocities have been extracted from SPIV results, while flame curvature and flame thermal thickness values have been calculated using the instantaneous temperature fields. The probability distributions of these quantities have been compared considering the separate influence of equivalence ratio stratification and turbulence. It has been observed that increased levels of turbulence determine higher turbulent burning velocities and flame front wrinkling. Flames characterized by stronger fuel stratification showed higher values in turbulent burning velocities. From the curvature analysis emerged that increased fuel concentration gradients favour flame wrinkling, especially when associated with positive small radius of curvature. This determines an increased surface area available for reaction that promotes a faster propagation of the flame front in the oncoming combustible mixtures.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
