方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Particle image velocimetry (PIV) is utilized with solid carbon dioxide (CO2) seeding material to conduct boundary layer measurements in the test section of the Air Force Research Laboratory’s Trisonic Gas-dynamics Facility (TGF), which has a 24 inch by 24 inch cross-section. Freestream velocity was set at Mach 0.3, Mach 0.5, or Mach 0.8 while stagnation pressure ranged from 500 to 2400 pounds per square foot (psf). High pressure liquid CO2 was directed through expansion nozzles into shroud tubes which led to solidified particles in the wind tunnel stagnation chamber. Two different sets of shroud tubes were used to modify the size of dry ice particles produced and the particle number density. Shroud tubes with an inside diameter (ID) of 0.824 inches provided good particle count and coverage for stagnation pressures between 500 and 1500 psf, while 0.364 inch ID shroud tubes demonstrated good particle count and coverage for stagnation pressures over 1000 psf. Overall, the PIV results produced freestream velocity measurements and boundary layer profiles which compared well with expected values. After initial processing, turbulence data closely followed trends expected within boundary layer, but levels were somewhat higher than anticipated. When the PIV data was processed using elliptical interrogation regions, elongated in the streamwise direction, resulting turbulence levels were much closer to expectations.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
