方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
We report particle image velocimetry measurements of the collision of a vortex ring with a heated wall kept at constant temperature. We consider the case when both the vortex ring and the thermal boundary layer generated by the vertical heated wall are stable and laminar prior to any interaction. The impingement process can be divided into two parts. sid A ring-driven stage, where the vortex ring grows in diameter while approaching the wall and therefore it sweeps progressively an increased surface on the wall. siid A boundary layer-driven stage, where the vortex ring moves upward due to the thermal convective motion generated by the heated wall. In some cases, the head-on collision triggers the ring’s azimuthal instability as revealed by the formation of vortical structures arranged on a wavy starlike pattern and confirmed by flow visualizations. A single collision generates important velocity gradients and shear stresses along the wall accompanied with the creation of local vorticity normal to the vertical heated wall. Peak wall shear stresses occur near the point of impact of the vortex ring core.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
